To close voters: This question is different from the question linked, because its scope is to find the options passed to ./configure during the building of a generic Debian package, not only to find the options passed to ./configure during the building of the Debian packages available in the repositories.
As the title said, I've unpacked a Debian package in order to recompile / rebuild it adding a custom option, but I can't sort out how to find the options passed to ./configure when the package was compiled / built in first place. Is finding such options feasible?
kos
  • 41,268
It may not be possible in a fully general sense, but if your deb came from Debian or Ubuntu directly (i.e., not a third-party deb), then it is required to be reproducible by autobuilders which do something like the following:
  • Start with a bare system- all Essential: yes or Priority: Required packages, plus build-essential, and any extra dependencies of these
  • Satisfy the build-depends and build-conflicts of the package to be built
  • Also satisfy build-depends-indep and build-conflicts-indep if appropriate, as determined by build type
  • Run debuild
You can read the precise steps that debuild takes in its man page, but the parts you probably care about are
  • debian/rules build (this should do all the configuration and building)
  • fakeroot debian/rules binary (this should "install" the built package into a directory tree which will be assembled into the final deb)
tl;dr: If the package build procedure did any ./configure-ing at all, you should find it in debian/rules.
the paul
  • 327
