If you download sublime text 2 from here, you will get Sublime Text 2.0.2.tar.bz2
After unpacking archive with command
tar xfvj Sublime\ Text\ 2.0.2.tar.bz2
you will get directory Sublime Text 2, go to dir
cd /path_to_dir/Sublime Text 2
and start text editor with command
./sublime_text
If you want to start text editor only with command sublime create sim link in /usr/bin
cd /usr/bin
sudo ln -s /path_to_dir/Sublime\ Text\ 2/sublime_text sublime
This link will allow to run text editor with command sublime
First part of problem is solved.
Exporting X Display via ssh you can have with option -X
ssh -l username ssh_server -X
With this command probably you will get your text editor in you display.
