Nvidia: Xorg crashes on 15.04: "drmSetMaster failed: Invalid argument"
On a clean install of Ubuntu GNOME 15.04, I get the following screen after installing the Nvidia proprietary driver:
starting version 219
[  OK  ] Started ACPI event daemon.
                    Starting ACPI event daemon...
_
The last few lines from Xorg.0.log:
<snip>
[     3.660] (II) intel(G0): [DRI2] Setup complete
[     3.660] (II) intel(G0): [DRI2]   DRI driver: i965
[     3.660] (II) intel(G0): [DRI2]   VDPAU driver: i965
[     3.660] (II) intel(G0): direct rendering: DRI2 enabled
[     3.660] (II) intel(G0): hardware support for Present enabled
[     3.660] (EE) modeset(G1): drmSetMaster failed: Invalid argument
[     3.660] (EE)
Fatal server error:
[     3.660] (EE) AddScreen/ScreenInit failed for gpu driver 1 -1
<snip>
[     3.661] (EE) Server terminated with error (1). Closing log file.
(complete log here)
I tried all available proprietary Nvidia drivers.
System specifications:
  • OS: Ubuntu GNOME 15.04
  • CPU: Intel i5-3570K
  • GPU: NVIDIA GeForce GTX 660
How can this error be resolved?
Silke
  • 1,182
First I switched to a console (CTRL-ALT-F1). Then I removed all nvidia stuff with
sudo apt-get autoremove --purge nvidia-*
and reinstalled the nouveau driver using
sudo apt-get install --reinstall xserver-xorg-video-nouveu
then
sudo reboot
I know this is probably not what both of us want but it is still better than no desktop at all...
My Setup (for completeness):
  • OS: Ubuntu 15.04
  • CPU: Intel i5-4570S
  • GPU: Nvidia GeForce GT 610
Philip
  • 29
The 'solution' for me is disabling the Intel integrated GPU. There are two ways to go about this:
UEFI/BIOS
Disable the Intel GPU in your UEFI/BIOS settings. How to go about this differs per motherboard. For an Asrock Z77 Pro4 it meant setting:
Advanced > North Bridge Configuration > IGPU Multi-Monitor: Disabled
On other motherboards it can probably be found in a similar location.
Blacklist Kernel Driver
The other option is to blacklist the kernel driver (i1915), which is explained in this answer.
Edit /etc/modprobe.d/blacklist.conf and add: blacklist i915.
This can be done by switching to a TTY (ctrl+alt+f1), logging in and running:
echo "blacklist i915" | sudo tee --append /etc/modprobe.d/blacklist.conf
After rebooting, the Intel GPU will no longer work but the Nvidia GPU will work and (hopefully) Xorg will no longer crash.
Silke
  • 1,182
Try to run nvidia-xconfig after nvidia drivers installation. Then reboot.
muru
  • 207,228
