I am trying to install a few different things and having issues.
I thought pip could have been the issue on one of the packages I was trying to install. So I decided to try to upgrade pip, following this reference:
https://pip.pypa.io/en/latest/installing.html#install-pip
So I ran :
sudo pip install -U pip
That output was:
Downloading/unpacking pip from https://pypi.python.org/packages/py2.py3/p/pip/pip-6.1.1-py2.py3-none-any.whl#md5=172eb5abab25a5e0f7a7b63c7a49378d
  Downloading pip-6.1.1-py2.py3-none-any.whl (1.1MB): 1.1MB downloaded
Installing collected packages: pip
  Found existing installation: pip 1.5.4
    Uninstalling pip:
      Successfully uninstalled pip
Successfully installed pip
Cleaning up...
Now however when I run:
pip install <package>
I get:
"bash: /usr/bin/pip: No such file or directory"
What can I do to get the new pip working? (And hopefully not have to re-install all of the packages that the older version of pip had installed).
I am very new Ubuntu and to using pip.
Additional:
I tried running:
easy_install pip
This gave me:
Searching for pip
Best match: pip 6.1.1
Adding pip 6.1.1 to easy-install.pth file
Installing pip script to /usr/local/bin
Installing pip3.4 script to /usr/local/bin
Installing pip3 script to /usr/local/bin
Using /usr/local/lib/python2.7/dist-packages
Processing dependencies for pip
Finished processing dependencies for pip
Still the pip command is not being recognized.
pip --version
More additional: I downloaded the get-pip.py and then ran python get-pip.py. This gave me an error something like "InsecurePlatformWarning"
wgwz
  • 131
Once you have upgraded pip you only needed to update your link to your new pip on /usr/bin
sudo ln -s /usr/local/bin/pip /usr/bin/
since the old one has been removed when you upgrade the pip package using pip ;-)
Then, you are ready to go :)
Ark74
  • 41
This is merely an issue of bash remembering where executables are located. The Ubuntu python-pip package installs the pip executable to /usr/bin/pip, but anything installed via pip goes to /usr/local, meaning it installs the pip executable to /usr/local/bin/pip. However, bash remembers that the command pip is located at /usr/bin/pip, because it has looked up the command before, and tries to execute that without actually searching the path.
You can fix this by running hash -r in all open bash shells, or by opening a new shell, or rebooting. Reinstalling the Ubuntu python-pip package means you will have two different versions of pip installed simultaneously - but /usr/local will be used before /usr, so it ends up working. It's just not an efficient way to do things. :)
kitti
  • 212
Try using the package from the repository,
sudo apt-get install python-pip
If this gives you errors, you might first want to do a
sudo apt-get remove python-pip
and then try again with install.
This also shouldn't interfere or remove the modules you already installed.
Sinn3d
  • 189
