I am trying to solve what might be an unsolvable broken system. Apparently virtuoso-nepomuk is tripping up something in the upgrade process and causing an unable to migrate to dependancy based boot sequencing error (or something like that). From what I can tell virtuoso-nepomuk is the package that is not playing well.
Can I remove it? What will break if I do?
For what it is worth I seem to be running 12.04 shell but seeing the version report as 14.10 so...
EDIT: Apparently it is not installed so why would it cause problems?
EDIT: However the script is still reporting as broken in the logs with a missing end of LSB comment (whatever that is)
