Is it possible to change some styles inside of the Ubuntu Software Center application?
For example, how can I change the rounded corners radius? Or how can I change the background color?
The answer would be divided into two parts:
To change the dialog shape
go to the directory:
/usr/share/software-center/ui/gtk3
Open the *.ui apps with GLADE. Edit whatever you want to do in appearance then save.
To install glade:
sudo apt-get install glade
for example here i change the message in the dialog that appears when something wrong goes in your sofwtare center
Enjoy this tricky
Now Also you can do some job when changing the css of the software center found in the path /usr/share/software-center/ui/gtk3/css.
Play with values in and see the difference and do what you want to.
For example:
open /usr/share/software-center/ui/gtk3/css/softwarecenter.css
@define-color light-aubergine #DED7DB;
@define-color super-light-aubergine #F4F1F3;
#featured-star {
border-color: #F89516; /* yellow */
color: #FFC51D; /* orange */
I would change the color of the star in the favorite part of software center
what I did is changing the border color and color of the featured star to black
#featured-star {
border-color: #000000;
color: #000000;
