I want to make a script that puts filenames from the working directory (with a specific extension) in text file with some additional strings:
For example, if I'm interested in files with extension i and files in my directory are:
1.b  1.i  2.i  2.z 3.i
I want to make a text file like:
command_1
command_2 1.i 1.o && command_2 2.i 2.o && command_2 3.i 3.o &
Zanna
  • 72,312
I found a better solution.
Skip making a text file and just made a script to execute multiple files in a folder
#!/bin/bash
for file in *.i*
do
  [[ "${file##*.}" =~ fchk ]] && continue
  qchem "$file" "${file%.*}".out
done
clear
echo "DONE!"
Zanna
  • 72,312
Considering your answer you don't really want to create a text file but just search for files and process them. You can use the find command for that, for example to rename all files ending in .i replacing i by o do:
find -maxdepth 1 -type f -name "*.i" -exec bash -c 'mv "$0" "${0/i/o}"' "{}" \;
Explanations
  • -maxdepth 1 stay in the current directory
  • -type f search files only
  • -name "*.i" search files ending in .i
  • -exec execute the following command on the file, {} is substituted by the file name, needs to be finished with \;
  • bash -c start a subshell running the following commands, by adding "{}" we give it the filename as argument 0
  • mv "$0" "${0/i/o}" rename the file by substituting i by o – just an example of course, can be replaced by any (chain of) commands you like
  • \; finishes the -exec option
For commands that can take more than one file at a time you can substitute \; by + to chain the arguments, see What is the difference between using '+' (plus) and ';' (semicolon) in -exec command?.
dessert
  • 40,956
An alternative if for some reason you want to use a file to store the list of files:
ls *.i  > input.txt
for F in $(cat /path/to/input.txt) ; do
done;
or, if you have spaces in your filenames
while read F  ; do
done </path/to/input.txt
Bruni
  • 11,099
