I've been trying to create a script that runs sudo apt-get update and sudo apt-get autoremove whenever I log in. It goes like this:
#!/bin/bash
(sudo apt-get update)
(sudo apt-get autoremove)
But whenever I run the script it freezes my computer. I'm assuming it's because it's waiting for the script to supply a password. Would it work if I added PASSWD:mypassword after the commands like this:
#!/bin/bash
(sudo apt-get update)PASSWD:mypassword
(sudo apt-get autoremove)PASSWD:mypassword
or is there something else I should do? Is there even a way? If so please tell me!
kos
  • 41,268
You don't actually have to include your password in your script (from what I have seen its generally not advisable to have your password in a script). Instead you can edit your sudoer file to allow you to run the apt-get command without the need for a password.
For more information go to this website.
open a terminal (ctrl + alt + T)
Enter the command
sudo visudo
At the end of the sudoers file type
username ALL=(ALL) NOPASSWD: /usr/bin/apt-get
Where username is your username (obviously)
editing this file will allow you to run any of the apt-get commands without entering a password. This means you can also install or upgrade packages without entering your password.
You can also add other comands to this list by entering the path to the command after a comma. The path to a command can be found by entering the following command in a terminal.
which command
Where command is the name of the command( for example reboot).
Rumesh
  • 1,449
The command to start a bash sccript :
#!/bin/bash
The command to ask for the users root password :
[ "$UID" -eq 0 ] || exec sudo bash "$0" "$@"
Example commands of what can be next :
apt-get update
apt-get upgrade --yes
shutdown -r now
Good luck with your script
-1
Try this script:
#!/bin/bash
echo "yourpassword" | sudo -S apt-get update
echo "yourpassword" | sudo -S apt-get autoremove
Here, you echo your password and the read the password using -S option (stdin option for sudo).
Rajesh N
  • 144
