I have a problem logging into Ubuntu under all of my usernames. I have tried many solutions. When I look at my .xsession-errors file, I get the following:
xlib: extension "GLX" missing on display ":o"
Script for ibus started at run_im.
Script for auto started at run_im.
Script for default started at run_im.
init: gnome-session (unity) main process (2292) terminated with status 1
init: unity-settings-deamon main process (2284) killed by TERM signal
init: logrotate main process (2192)killed by TERM signal
init: update-notifier-crash (/var/crash/_usr_bin_compiz.1000.crash) main process (2230) killed by TERM signal
init: xsession-init main process (2201) killed by TERM signal
init: hud main process (2288) killed by TERM signal
init: unity=panel service main process (2299) killed by TERM signal
init: Disconnected from notified D-Bus bus
init: window-stack-bridge main process (2215) killed by KILL signal
A.B.
  • 92,125
Ben
  • 161
Short Solution
Try to install linux-headers-generic and reboot to login again:
# apt-get install linux-headers-generic
Longer Story
Same issue here. I've tried serveral ways in askubuntu and stackoverflow but in vain. I write down my solution and hope it will help others.
This issue happens after I use apt-get purge to remove all kernels accidentally, then I install linux-image-generic and hope everything is ok. However, I meet this issue after reboot, .xsession-errors shows almost same message (just pids are different).
After one hour, I found linux-headers-generic is not just header files. It will also recompile necessary components. In my case it's nvidia driver.
After install linux-headers-generic and reboot, everything is back to normal.
