-2
when I update using 'apt-get update' on ubuntu-14.04, I got the following error,
W: GPG error: http://packages.osrfoundation.org trusty InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 67170598AF249743
I've tried following command given in some forum
apt-key adv --keyserver keyserver.ubuntu.com --recv-key 67170598AF249743
the output is as follows
Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --homedir /tmp/tmp.XI2D9gTkMc --no-auto-check-trustdb --trust-model always --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --keyserver keyserver.ubuntu.com --keyserver-options http-proxy=http://202.141.80.80:3128 --recv-key 67170598AF249743
gpg: requesting key AF249743 from hkp server keyserver.ubuntu.com
gpgkeys: key 67170598AF249743 not found on keyserver
gpg: no valid OpenPGP data found.
gpg: Total number processed: 0
and I've tried
 gpg --keyserver keyserver.ubuntu.com --recv-key 67170598AF249743
the output is
with command gpg -a --export 67170598AF249743 | sudo apt-key add -, I got the following result
gpg: WARNING: nothing exported
and still I get the GPG error same as above, can anyone suggest me a solution?
A.B.
  • 92,125
Karteek
  • 59
seems keyserver.ubuntu.com is missing gpg keys for packages.osrfoundation.org
Download gazebo.key from below using wget..
wget  http://packages.osrfoundation.org/gazebo.key
and import it
sudo apt-key add gazebo.key
Then try
sudo apt-get update && sudo apt-get upgrade
Aravinda
  • 992
