I can't seem to remove a package.
I've tried dpkg --purge and apt-get purge. Neither seem to actually remove the package, however. The package is mfc8840dlpr (1.1.2-1).
Is there any way I can make this question clearer, or more specific?
Someone seems to have solved a similar problem, as follows, but it doesn't have much about how to actually remove the package:
How to fix a dpkg broken by the Brother MFC-7340 deb driver
Has anyone else come across this problem with a Brother printer driver .deb installation?
The output from my attempts follows:
(Reading database ... 471289 files and directories currently installed.)
Removing mfc8840dlpr (1.1.2-1) ...
/var/lib/dpkg/info/mfc8840dlpr.postrm: 3: /var/lib/dpkg/info/mfc8840dlpr.postrm: /etc/init.d/lpd: not found
dpkg: error processing package mfc8840dlpr (--remove):
 subprocess installed post-removal script returned error exit status 127
 mfc8840dlpr
$ dpkg --purge mfc8840dlpr
dpkg: error: requested operation requires superuser privilege
$ sudo dpkg --purge mfc8840dlpr
dpkg: error processing package mfc8840dlpr (--purge):
 mfc8840dlpr
$ sudo apt-get purge mfc8840dlpr
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
  mfc8840dlpr:i386
0 upgraded, 0 newly installed, 1 to remove and 12 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
 mfc8840dlpr
Nathan Basanese
  • 422
  • 17
I just installed the package and could reproduce the problem.
This command has solved the problem:
sudo rm /var/lib/dpkg/info/mfc8840dlpr.*
This removes the installation files the mfc8840dlpr package, which will prevent any further automatic attempts to complete installation. This will also leave the system in a state of thinking that the mfc8840dlpr package is installed, when really it is perhaps not.
Jeremy Kerr
  • 27,829
A.B.
  • 92,125
