I can't apt-get upgrade, I also tried installing software with the software center but no luck since those libs need dependencies. I tried removing them but that didn't work and I also tried various other commands, like sudo apt-get clean, sudo apt-get dist-upgrade, sudo apt-get remove, sudo dpkg --configure -a, and sudo apt-get -f install.
Software Center:
installArchives() failed: (Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 206010 files and directories currently installed.)
Preparing to unpack .../libc6-dev-i386_2.19-0ubuntu6.6_amd64.deb ...
Unpacking libc6-dev-i386 (2.19-0ubuntu6.6) ...
dpkg: error processing archive /var/cache/apt/archives/libc6-dev-i386_2.19-0ubuntu6.6_amd64.deb (--unpack):
trying to overwrite '/usr/include/bits', which is also in package libc6-dev-amd64 2.19-0ubuntu6.6
Error in function:
dpkg: dependency problems prevent configuration of gcc-4.8-multilib:
gcc-4.8-multilib depends on libc6-dev-i386 (>= 2.11); however:
Package libc6-dev-i386 is not installed.
dpkg: error processing package gcc-4.8-multilib (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of libc6-dev-x32:
libc6-dev-x32 depends on libc6-dev-i386 (= 2.19-0ubuntu6.6); however:
dpkg: error processing package libc6-dev-x32 (--configure):
dpkg: dependency problems prevent configuration of gcc-multilib:
gcc-multilib depends on gcc-4.8-multilib (>= 4.8.2-5~); however:
Package gcc-4.8-multilib is not configured yet.
dpkg: error processing package gcc-multilib (--configure):
dpkg: dependency problems prevent configuration of g++-4.8-multilib:
g++-4.8-multilib depends on gcc-4.8-multilib (= 4.8.2-19ubuntu1); however:
dpkg: error processing package g++-4.8-multilib (--configure):
dpkg: dependency problems prevent configuration of g++-multilib:
g++-multilib depends on gcc-multilib (>= 4:4.8.2-1ubuntu6); however:
Package gcc-multilib is not configured yet.
g++-multilib depends on g++-4.8-multilib (>= 4.8.2-5~); however:
Package g++-4.8-multilib is not configured yet.
dpkg: error processing package g++-multilib (--configure):
apt-get upgrade:
keegan@keeganserver:~$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
gcc-4.8-multilib : Depends: libc6-dev-i386 (>= 2.11) but it is not installed
libc6-dev-x32 : Depends: libc6-dev-i386 (= 2.19-0ubuntu6.6) but it is not installed
E: Unmet dependencies. Try using -f.
With -f:
keegan@keeganserver:~$ sudo apt-get -f install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
cpp-4.4 diffstat gcc-4.4-base intltool-debian libalgorithm-diff-perl
libalgorithm-diff-xs-perl libalgorithm-merge-perl libapt-pkg-perl
libarchive-zip-perl libautodie-perl libclass-accessor-perl libclone-perl
libdpkg-perl libemail-valid-perl libfile-fcntllock-perl libio-pty-perl
libio-string-perl libipc-run-perl libipc-system-simple-perl
liblist-moreutils-perl libnet-dns-perl libnet-domain-tld-perl libnet-ip-perl
libparse-debianchangelog-perl libperlio-gzip-perl libsub-identify-perl
libsub-name-perl libtext-levenshtein-perl libupstart1 patchutils t1utils
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
libc6-dev-i386
The following NEW packages will be installed:
libc6-dev-i386
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
5 not fully installed or removed.
Need to get 0 B/1,148 kB of archives.
After this operation, 6,333 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
