I've got the following problem: I had a ssd (sda) with windows 8 installed. Now I added another ssd (sdb) and installed ubuntu 14.10 on it, but I didn't create a efi partition and installed to sda.
So after the installation completed, I could only start ubuntu.
After that I tried to reinstall ubuntu with the boot manager installed to an efi partition on sdb, but this failed and now i can't boot in any system.
So my question is, how can I restore the windows installation/bootloader.
Thank you in advance
  1. Burn this to a CD or USB drive: http://sourceforge.net/p/boot-repair-cd/home/Home/.
  2. Boot from that disk and run Boot Repair to get Ubuntu working again.
  3. Once you boot into Ubuntu, open a terminal and run sudo update-grub. This should add the Windows bootloader to the GRUB menu and you can then reboot into GRUB and select Windows.
TheWanderer
  • 19,525
  • 52
  • 65
