There is any good program to download YouTube videos? I am using Ubuntu 14.04 32-bit.
To install youtube-dl:
Recommended way (latest version):
- Open a terminal with Ctrl+Alt+T or searching Terminal in the dash.
Install
youtube-dlwith this command (you'll be prompted for your password):sudo wget https://yt-dl.org/downloads/latest/youtube-dl -O /usr/local/bin/youtube-dl && sudo chmod a+x /usr/local/bin/youtube-dl
Not recommended way (older version):
Install
youtube-dlwith this command (you'll be prompted for your password):sudo apt-get install youtube-dl
To use youtube-dl:
- To select where to save the video, you can follow these steps:
- Type
cdon the terminal. - Press Space
- Drag the folder from File Manager and drop it on the terminal.
- If you skip this step, the video will be saved on your home folder.
- Type
To download the video you can use one of these procedures:
2.1. Run
youtube-dl video_urlwherevideo_urlis the URL of the video.2.2. If you want to download many videos, you can follow these steps instead of 2.1:
Run the below command:
xargs youtube-dl- Repeat the following procedure for each link:
- Paste a link.
- Press Enter
- Press Ctrl+D
2.3. If do you have a plain text file with a list of links, you can download them this way:
- Type
caton the terminal. - Press Space
- Drag the file form the File Manager and drop it on the terminal.
- Press Space
- Type
| xargs youtube-dl - Press Enter
Now the video(s) will download to the selected folder.
Some final thoughts:
On the method 2.3 the final command should look like this:
cat '/home/foo/Desktop/myawesomevideos.txt' | xargs youtube-dl- You can also use the URL of a channel and
youtube-dlwill save the entire channel. - You can update
youtube-dlwithsudo youtube-dl -U - You can see all the options of
youtube-dlwithyoutube-dl --help
Thanks to user185719 and Michael Grünewald for their contributions to this answer.
You can use firefox as the browser and there are some addons which will enable you to download videos from youtube like this
- 510
simply open an additional tab in the same browser and search for savefrom.net and open the website. Now open the youtube video and copy the URL when it starts playing. Paste that in the space given for URL in the savefrom.net website.
