I've run a casual apt-get update && apt-get upgrade command. The process completed (with an error): You might want to run 'apt-get -f install' to correct these.
libgcrypt11 : Breaks: libgcrypt11:i386 (!= 1.5.0-3ubuntu0.3) but 1.5.0-3ubuntu0.4 is installed
libgcrypt11:i386 : Breaks: libgcrypt11 (!= 1.5.0-3ubuntu0.4) but 1.5.0-3ubuntu0.3 is installed
E: Unmet dependencies. Try using -f..
I tried to run apt-get -f install, but it gave an error too:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following extra packages will be installed:
libgcrypt11
Suggested packages:
rng-tools
The following packages will be REMOVED:
libxslt1.1:i386
The following packages will be upgraded:
libgcrypt11
1 upgraded, 0 newly installed, 1 to remove and 77 not upgraded.
3 not fully installed or removed.
Need to get 0 B/282 kB of archives.
After this operation, 477 kB disk space will be freed.
Do you want to continue [Y/n]? y
(Reading database ... 1288453 files and directories currently installed.)
Removing libxslt1.1:i386 ...
dpkg: unrecoverable fatal error, aborting:
fork failed: Cannot allocate memory
E: Sub-process /usr/bin/dpkg returned an error code (2)'.
I tried to run dpkg --configure -a, but there was another pitfall:
dpkg: error processing libgcrypt11 (--configure):
libgcrypt11:amd64 1.5.0-3ubuntu0.3 cannot be configured because libgcrypt11:i386 is in a different version (1.5.0-3ubuntu0.4)
libgcrypt11
So I'm stuck with updates. I tried to remove libgcrypt with aptitude, but I ran into the same issue. I am completely clueless. Any help would be appreciated!
