Trying to run OpenForis Calc, embedded Tomcat instance fails.
Error seems to appear here:
Apr 17, 2015 2:13:47 AM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor /opt/OpenForisCalc/calc-server/tomcat/conf/Catalina/localhost/calc.xml
Apr 17, 2015 2:13:58 AM org.apache.catalina.core.StandardContext startInternal
SEVERE: Error listenerStart
Then if messes up with the rest (this repeats a lot):
SEVERE: Context [/calc] startup failed due to previous errors
David Foerster
  • 36,890
  • 56
  • 97
  • 151
I assume this is because Calc isn't able to access the PostgreSQL database. Double-check if PostgreSQL is running:
sudo service postgresql status
should return something like
9.3/main (port 5432): online
If PostgreSQL is running, check the credentials. By default, there's no admin password set for PostgreSQL. Calc assumes postgres as admin password, by default. So, if you didn't set a password yet, follow the instructions to do so:
  1. Start the postgresql command line client as user postgres:
    sudo -u postgres psql postgres
  2. Inside the client:
    \password postgres
  3. Now, you can enter the admin password - you should choose a secure one!
If you want to change the password Calc is using (maybe because you've choosen a more secure one): open the following file with your favorite text editor:
and look for a line looking like:
<Parameter name="calc.jdbc.adminpassword" value="postgres" />
EDIT:
If you still encounter problems, you should check the logs directly. You'll find them in
/opt/OpenForisCalc/calc-server/tomcat/logs
There should be a log file calc.log - check its contents for errors.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
tohuwawohu
  • 7,502
