I have Ubuntu 14.04 LTS installed on my laptop, I am using 3G USB modem to connect to the internet (sometimes I do not have direct access to this laptop, but I need it to stay online). But every day or two it keeps disconnecting from this network. I was wondering, is there any way to set the system to connect automatically at specific time?
You can use nmcli and cron to bringing up connection at specific time.
First you create connection using Network-Manager.
Then start terminal to test some things
  • list all NM connections: nmcli con
  • start connection: nmcli con up id ConnectionName
  • down connection: nmcli con down id ConnectionName
If work, setup cron to trigger connection
sudo crontab -e
at the end add
45 10 * * * nmcli con up id bdc
this will trigger command every day at 10 h and 45 min. In cron you can specify min, hour, day, month ... Also you can start connectio every min
* * * * * nmcli con up id bdc
More example how to setup time in cron can find here
2707974
  • 10,758
