I want to login to Ubuntu through command line which will then redirect me to GUI, is there any way to do this?
To boot straight to the command line you need to modify GRUB.
  1. Edit grub config file sudo nano /etc/default/grub
  2. Change the option GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" to read GRUB_CMDLINE_LINUX_DEFAULT="text"
  3. Save the file and exit CTRL+X, press Y and then ENTER
  4. Type sudo update-grub from the terminal to update the GRUB bootloader with your new configuration.
  5. Reboot and you should be presented with a terminal instead of X.
  6. Type startx to load the default shell.
ash
