while installing a newer latest version of r by removing the previous version of r(3.0.2) I got the following problem.
anupam :~$ sudo apt-get install r-base
Reading package lists... Done
Building dependency tree
 r-base : Depends: r-base-core (>= 3.1.3.20150410-1trusty) but it is not going to be installed
          Depends: r-recommended (= 3.1.3.20150410-1trusty) but it is not going to be installed
          Recommends: r-base-html but it is not going to be installed
I have gone through the the most voted answer installing latest version of R on ubuntu ,,
I tried installing it from aptitude too.. but it didn't worked I tried for sudo apt-get autoclean too .. how could I resolve this ??
Anupam
  • 1,573
As you have trusty (14.04), and not precise (12.04), the line
deb http://cran.rstudio.com/bin/linux/ubuntu precise/ needs to be
deb http://cran.rstudio.com/bin/linux/ubuntu trusty/.
Change that line, then run
sudo apt-get update
sudo apt-get install r-base.
mikewhatever
  • 33,013
