I'm trying to setup some samba shares in 14.04. After defining the shares, I can connect and also list the defined shares, but when I try to mount a share, I get the error: NT_STATUS_ACCESS_DENIED (using smbclient on the command line)
Here's my smb.conf:
[global]
server string = %h server (Samba, Ubuntu)
server role = standalone server
map to guest = Bad User
obey pam restrictions = Yes
pam password change = Yes
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
unix password sync = Yes
syslog = 0
log file = /var/log/samba/log.%m
max log size = 1000
dns proxy = No
usershare allow guests = Yes
panic action = /usr/share/samba/panic-action %d
idmap config * : backend = tdb
guest ok = Yes
[Share01]
path = /media/username/Data HD/Folder01
directory mask = 0777
[Share02]
path = /media/username/Data HD/Folder02
I'm using Samba 4.1.6, which is installed automatically if you want to share a folder from Unity.
Update: I've added a share pointing to a folder inside my home folder, that works. The two shares above (Share01 and Share02) point to folders on an external harddrive. Both internal and external HD have EXT4 filesystems.
Thanks for your help!
