So, I went and did something very stupid. I have ubuntu-toolchain-r repository added to repositories which has up to some time ago provided libgcc1:i386 among other things. For a some time now the i386 packages have been shown as kept back during upgrades. I've ignored those since they are rather vital libraries but today I decided to look into it a bit.
I stumbled upon this "The following packages have been kept back:" Why and how do I solve it? and went to use the aptitude gui approach without realizing that it shall do basically the same thing as apt-get dist upgrade and as the gui hanged for a while, it took in my key presses after a while without me having a chance to do anything before it started to do some horrid package removing to my misfortune. I went and killed the aptitude process but a lot of damage was already done.
So afterwards killing aptitude I carefully went through the list of packages that it had removed and re-installed those. All except the ones that need ia32-libs or libc6:i386, meaning for example my wine and lots of other 32-bit applications and packages that I use because it all comes down to the fact that I can't re-install libgcc1:i386 package since it breaks libgcc1 package and vice versa (same goes for libstdc++6).
ahti@ahti:~$ sudo apt-get install libgcc1:i386
Reading package lists... Done
Building dependency tree
 libgcc1 : Breaks: libgcc1:i386 (!= 1:4.9.2-0ubuntu1~12.04) but 1:5-20150401-0ubuntu12~12.04 is to be installed
 libgcc1:i386 : Breaks: libgcc1 (!= 1:5-20150401-0ubuntu12~12.04) but 1:4.9.2-0ubuntu1~12.04 is to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
So previously libgcc1:i386 was kept back in my system not causing any problems. Now that it's not there anymore and can't be re-installed it's bringing me a lot of things I can't re-install or use.
Here are results for apt-cache policy command:
ahti@ahti:~$ apt-cache policy libgcc1
libgcc1:
  Installed: 1:4.9.2-0ubuntu1~12.04
  Candidate: 1:4.9.2-0ubuntu1~12.04
  Version table:
 *** 1:4.9.2-0ubuntu1~12.04 0
        500 http://ppa.launchpad.net/ubuntu-toolchain-r/test/ubuntu/ precise/main amd64 Packages
        100 /var/lib/dpkg/status
     1:4.6.3-1ubuntu5 0
        500 http://fi.archive.ubuntu.com/ubuntu/ precise/main amd64 Packages
ahti@ahti:~$ apt-cache policy libgcc1:i386
libgcc1:i386:
  Installed: (none)
  Candidate: 1:5-20150401-0ubuntu12~12.04
  Version table:
     1:5-20150401-0ubuntu12~12.04 0
        500 http://ppa.launchpad.net/ubuntu-toolchain-r/test/ubuntu/ precise/main i386 Packages
     1:4.6.3-1ubuntu5 0
        500 http://fi.archive.ubuntu.com/ubuntu/ precise/main i386 Packages
Also I do have foreign-architecture i386 in my /etc/dpkg/dpkg.cfg.d/multiarch and here's a result of aptitude install wine command.
Is there anything I can do? This was a classic case of "if it ain't broken, don't fix it". Please help?
My system is 64-bit Ubuntu 12.04.5 with 3.2.0-80-generic kernel and gnome-session-fallback.
Ahti Komu
  • 542
Have you tried installing the libgcc1 package that is requested?
sudo apt-get install libgcc1:i386=1:4.9.2-0ubuntu1~12.04
or pin it:
sudo sh -c "echo -e 'Package: libgcc1:i386\nPin: version 1:4.9.2*\nPin-Priority: 500'  > /etc/apt/preferences.d/multiarch-libgcc1"
fritz
  • 31
