I have changed my .bashrc file, so that $LANG variable is always set to en_US when I run new shell. This is because I have a program for making plots which takes the sign as a decimal separator based on the language.
When $LANG is set to pl_PL then I have a comma, instead of a point.
It was all fine, but after I made automatic update to my system, it turned out that I cannot type in polish signs into terminal.
For instance this is unicode for "ó" letter: U+00D3 but I see "C3" when I type "ó' into the terminal.
Now, when I switch to another account, the problem is gone.
I checked content of
/var/lib/locales/supported.d/local
It says:
pl_PL.UTF-8 UTF-8
en_US.UTF-8 UTF-8
I also run
dpkg-reconfigure locale
It doesn't do any good.
What can I do if I don't want to switch to another account?
A.B.
  • 92,125
Somehow I have managed to solve the problem. I have hashed out export LANG=en_US in .bashrc file. And now I use
export LC_NUMERIC=C
to get point as a decimal separator. After I restarted system I got my polish signs back.
There is a bug in debian. Look at: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=818065#85 You have to do:
rm /etc/console-setup/cached_*
These files can be recreated by
setupcon --save-only
This wiil do the change in:
/etc/console-setup/cached_setup_keyboard.sh
-loadkeys '/tmp/tmpkbd.iDWdSi' > '/dev/null'
+loadkeys '/etc/console-setup/cached_UTF-8_del.kmap.gz' > '/dev/null'.
Yep they did not fix this yet.
