I can't kill viber process in terminal.
$ pkill Viber
or
$ pgrep Viber
2849
$ kill 2849
or
$ killall -v Viber
Killed Viber(2849) with signal 15
do not work.
But in System Monitor choosing "Kill Process" from the right-click menu will kill it.
pomsky
  • 70,557
hadi aj
  • 191
Type killall -9 viber.
  1. A SIGTERM or a signal 15 allows a process to end gracefully.
  2. A SIGKILL or a signal 9 kills the process immediately.
By default, kill and killall will send a SIGTERM, so the process should end in a few seconds, but if a process is completely unresponsive, you can specify SIGKILL which will kill the process immediately:
Use SIGKILL only as a last resort.
The -v or --verbose option asks killall to be more elaborate on what it's doing. Hence it says it tried to kill the process with a signal 15, i.e SIGTERM.
Read more about the signals here.
Because you have to kill Viber, not viber. Had the same problem and was wondering why. Running killall -9 Viber would be best.
lion
  • 91
