I've installed Debian in my VirtualBox (my host OS is Ubuntu). And there I configured two network interfaces: eth0 as NAT, and eth1 as Bridge.
NAT I need to have access to the internet in virtual OS, but Bridge I need because I want this virtual OS to be a part of my local network.
How to switch from these network interfaces? For example now I use eth0 (NAT), but some time later I need to turn off eth0 and turn on eth1.
P.S. There is no Desktop Environment in guest OS (Debian), so I need to do this in terminal.
Thanks in advance.
If both interface are configured in /etc/network/interfaces you can use
sudo ifup eth0
to bring eth0 up and
sudo ifdown eth0
to take eth0 down
Normally I use
sudo ifdown eth0 && ifup eth1
sudo ifdown eth1 && ifup eth0
The 1st stops eth0 and starts eth1 and the second does it the other way around.
Rinzwind
  • 309,379
On a virtualbox running Ubuntu 16.04
sudo ifdown eth0 didn't work giving Unknown interface eth0
I needed to do this instead:
Turn off network:
sudo ifconfig eth0 down
Turn on network:
sudo ifconfig eth0 up
(In my case there was no eth0 but there was enp0s3 so I replaced that above.)
User
  • 1,493
