I have very specific questions regarding permissions. I have delved into the FilePermissions Wiki - https://help.ubuntu.com/community/FilePermissions
Recently I installed an ecommerce open source software on my LAMP server. It needed some permissions to be given.These were the two lines I executed ,blindly, in the terminal for all the permissions it needed-
sudo chown www-data:www-data * -R
sudo usermod -a -G www-data $username
Please explain what these two lines of code did. The MAIN REASON I am posting this question is because now it has locked some of my folders How do I revert all those permissions back to normal? How would I know which folders' permission it has changed and what were their normal permissions? What is the difference between chmod and chown and which should be used here?
JoKeR
  • 7,062
The above command has changed ownership of all directories, sub-directories and files of your home directory from default to www-data user and www-data group
This command has added a new user www-data and new group www-data.
You can revert changes back to normal by this command
sudo chown username:username * -R
Replace username with your actual user_name
chmod changes file and directory permissions whereas chown changes ownership.
Faizan Akram Dar
  • 4,569
  • 25
  • 31
Short answer:
usermod The usermod command modifies the system account files to reflect the changes that are specified on the command line. as outlined in man usermod
chown changes ownership as outlined in man chown
Long answer: chown -R operates recursively so sudo chown -R www-data:www-data *
changes ownership of every file from the current directory down through all it's subdirectories to be owned by user www-data and group www-data.
usermod -a -G www-data $username appends www-data to the groups to which $username belongs. Unless you have an environment variable that will be expanded you'll need to replace $username with the actual username.
To return the permissions to defaults please see default permissions for /var/www
Elder Geek
  • 36,752
