I wrote a script in bash to basically create aliases, but for any reason, it doesn't work in some cases. Here it's the code:
#!/bin/bash
#Script to create unique and permanent aliases
_add_alias()
    echo "alias $1='$2'" | sudo tee -a $HOME/.bash_aliases
    echo "Alias successfully created"
if [ `cat $HOME/.bash_aliases | grep "alias $1=" | wc -l` == 0 ]
    then
    if [ $# -eq 2 ]
        then
        if [ -f "$2" ] #This condition is always false, don't know why.
            then
            _add_alias $1 "$2"
        elif $2 > tmp.txt 2> tmp.txt
            then
            _add_alias $1 "$2"
        else
            echo "Wrong command"
        fi
        rm tmp.txt
    elif [ $# -gt 2 ]
        then
    echo "Error: Usage: addal alias_name 'command' (comand between quotes)"
    elif [ $# -lt 2 ]
        then
        echo "Wrong number of parameters"
    fi
else
    echo "Alias name already exists"
fi
I hope you could help me fix the script.
0x2b3bfa0
  • 9,110
  • 38
  • 55
Here you're a corrected and improved script:
#!/bin/bash
## Script to create permanent and unique aliases ##
## alias is equal to the first argument.
alias="$1"
## command is equal to an array holding all
## the positional parameters minus the first.
## (i.e. for "ls -la" it would be ["ls, "-la"]).
command=("${@:2}")
## If .bash_aliases exists, load it. Now the alias check
## will take in account any alias not sourced yet on the current shell.
test -f ~/.bash_aliases && source $_
## If there are less than 2 parameters, prints the usage and exits.
if [ $# -lt 2 ]; then
    echo "Usage: $0 <alias_name> <command>"
    exit 1
fi
## If the command is not valid, prints an error and exits.
if ! type "${command[0]}" &> /dev/null; then
    exit 3
fi
## If the current alias already exists, prints a error message and then exits.
if [[ "$(type -t '$alias')" == "alias" ]]; then
    echo "This alias alredy exists"
    exit 2
fi
## Append the alias to the .bash_aliases file.
echo "alias $alias='${command[@]}'" >> ~/.bash_aliases
## Print a sucess message.
echo "Alias '$alias' linked to the command '${command[@]}'!"
Things that I changed:
  • Commented code.
  • Used type to detemine if the alias already exists.
  • Removed the function because I think that is not necessary.
  • Used type to detemine if a command is valid or not.
  • Removed some unnecessary elif.
  • Improved the conditionals.
  • command may be unquoted (i.e. myscript pingoogle ping google.com)
0x2b3bfa0
  • 9,110
  • 38
  • 55
Here are your errors (source):
  • SC2002 Useless cat. Consider 'cmd < file | ..' or 'cmd file | ..' instead.
  • SC2006 Use $(..) instead of legacy `..`.
  • SC2046 Quote this to prevent word splitting.
  • SC2086 Double quote to prevent globbing and word splitting.
  • SC2126 Consider using grep -c instead of grep|wc.
   1  #!/bin/bash
   2  #Script to create unique and permanent aliases
   4  _add_alias()
   5  {
   6      echo "alias $1='$2'" | sudo tee -a $HOME/.bash_aliases
                                             ^––SC2086 Double quote to prevent globbing and word splitting.
   7      echo "Alias successfully created"
   8  }
  10  if [ `cat $HOME/.bash_aliases | grep "alias $1=" | wc -l` == 0 ]
           ^––SC2046 Quote this to prevent word splitting.
           ^––SC2006 Use $(..) instead of legacy `..`.
                ^––SC2002 Useless cat. Consider 'cmd < file | ..' or 'cmd file | ..' instead.
                                      ^––SC2126 Consider using grep -c instead of grep|wc.
  11      then
  12      if [ $# -eq 2 ]
  13          then
  14          if [ -f "$2" ] #This condition is always false, don't know why.
  15              then
  16              _add_alias $1 "$2"
  17          elif $2 > tmp.txt 2> tmp.txt
  18              then
  19              _add_alias $1 "$2"
  20          else
  21              echo "Wrong command"
  22          fi
  23          rm tmp.txt
  24      elif [ $# -gt 2 ]
  25          then
  26      echo "Error: Usage: addal alias_name 'command' (comand between quotes)"
  27      elif [ $# -lt 2 ]
  28          then
  29          echo "Wrong number of parameters"
  30      fi
  31  else
  32      echo "Alias name already exists"
  33  fi
A.B.
  • 92,125
Some thoughts:
myscript alias1 "$HOME/dir/ascript"
will evaluate in test part to
[ -f '/home/me/dir/ascript' ]
which may be true or false.
myscript alias2 '$HOME/dir/anotherscript'
[ -f '$HOME/dir/ascript' ]
which is always false (unless you have a dir named $HOME in local dir).
and
myscript alias3 "$HOME/dir/sample.sh foo bar"
[ -f '/home/me/dir/sample.sh foo bar' ]
which is false, unless there is a 'sample.sh foo bar' file in /home/me/dir.
and you should fix .bash_aliases and use
echo "alias $1='$2'" >> $HOME/.bash_aliases
muru
  • 207,228
Archemar
  • 682
