I used the Android "Gallery" app and accidentally deleted all my photos.
Can I plug my memory stick into Ubuntu, and DD recover the disk, and somehow recover the files?
David Foerster
  • 36,890
  • 56
  • 97
  • 151
You can use Photorec to recover the images. Run with no arguments and follow instructions, it should guide you step by step
sudo photorec
I would suggest following the guide here https://help.ubuntu.com/community/DataRecovery#Imaging_a_damaged_device.2C_filesystem_or_drive to image the card before just in case
EDIT: Also before you go through the trouble try plugging the sd card into the computer and checking through all the folders (look at hidden too) I seem to remember a trash folder, Android might have put them there
Igor Putilov
  • 101
