37
I have Ubuntu-Gnome 14.04 (Gnome 3.12.2).
When I try to run gnome-terminal by following command :
$ gnome-terminal
Error constructing proxy for org.gnome.Terminal: /org/gnome/Terminal/Factory0:
Error calling StartServiceByName for org.gnome.Terminal:
GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited:
Process /usr/lib/gnome-terminal/gnome-terminal-server exited with status 8
dessert
  • 40,956
12 Answers12
28
You have to add LANG=en_US.UTF-8 to /etc/default/locale and reboot your system. (Solution from this Arch Linux forum post.)
muru
  • 207,228
23
Here is the list of commands which helps me:
sudo apt install dconf-cli
Reinstalling terminal
dconf reset -f /org/gnome/terminal sudo apt-get remove gnome-terminal sudo apt-get install gnome-terminal
Reconfiguring locale
sudo locale-gen --purge sudo dpkg-reconfigure locales
reboot
As you can see I just reconfigured the locale and reinstall gnome-terminal
14
This is a winner for me:
/usr/bin/dbus-launch /usr/bin/gnome-terminal &
as learned here
BarryPye
  • 241
I had this problem when I created a new Ubuntu 16.04.3 LTS Desktop. The fix was to edit the /etc/default/locale file by adding the following line to the end of the file:
LC_ALL="en_US.UTF-8"
Then reboot and the problem was gone.
dessert
  • 40,956
TomH
  • 71
This might be an issue with your locales. Either add LANG=en_US.UTF-8 to /etc/locale.conf and reboot or delete that file altogether (sudo rm /etc/locale.conf && sudo locale-gen en_US.UTF-8 && sudo dpkg-reconfigure locales) and reboot.
xjcl
  • 653
I had to combine answers from @TomH and @BarryPye. To get a gnome-terminal window:
LC_ALL=en_US.UTF-8 /usr/bin/dbus-launch gnome-terminal
In my case, the issue was occuring in a VNC session. I fixed it in my ~/.vnc/xstartup by changing the window manager invocation to:
LC_ALL=en_US.UTF-8 /usr/bin/dbus-launch /bin/gnome-session
Then gnome-terminal starts directly from command or the gnome graphical launcher, without the need to extra dbus-launch commands.
I was at work today and desperate to get things moving. I found this
Execute sudo dpkg-reconfigure locales in an alternative terminal emulator and select en_US.UTF-8 UTF-8 , choose it as the default locale. gnome-terminal should work.
Another cause of the problem is that new preferences have been activated at the start of the session, check "Applications at startup" Preferences
If anyone hits this error using waypipe, the answer above by BarryPye shows the way.
e.g. waypipe --compress lz4 ssh user@host "/usr/bin/dbus-launch /usr/bin/gnome-terminal &"
If none of the above works for you, it could be that DBUS_SESSION_BUS_ADDRESS environment variable is not set.
See if it's set with echo $DBUS_SESSION_BUS_ADDRESS.
If it's empty, set it with export DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/$UID/bus. You could also put this in your ~/.bashrc.
Resourcese: Dconf, can read value but not write it (given address is empty)
kaixqu
I received this error on wsl, and apparently dbus-launch wasn't installed on the system. apt-get install dbus-launch will fix it in that case. Note that I also updated my /etc/defaults/locale as described by others, but it won't work if you don't have dbus-launch, obviously.
