I just upgraded and lost the wireless connection. Here some basic information which might be helpful:
- Dell Inspiron i3-3217U Dual-Core CPU @ 1.8GHz 64-bit
- Chip ID: BCM43143
- PCI-ID: 14e4:4365
- Kernel driver in use: bcma-pci-bridge
Below the result of the sudo lshw -C network command:
*-network
description: Ethernet interface
product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: eth0
version: 05
serial: 34:17:eb:54:39:dd
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl_nic/rtl8105e-1.fw latency=0 link=no multicast=yes port=MII speed=10Mbit/s
resources: irq:41 ioport:2000(size=256) memory:c0404000-c0404fff memory:c0400000-c0403fff
*-network
description: Network controller
product: BCM43142 802.11b/g/n
vendor: Broadcom Corporation
physical id: 0
bus info: pci@0000:02:00.0
version: 01
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=bcma-pci-bridge latency=0
resources: irq:17 memory:c0500000-c0507fff
*-network
physical id: 0
logical name: eth0
version: 05
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
*-network
physical id: 0
version: 01
width: 64 bits
clock: 33MHz
and the rfkill list:
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Many thanks in advance
