The Ubuntu Software Centre has an older version and downloading Audacity from the website gave me a folder that doesn't seem to have a binary to start the program. How do I install version 2.1.0 in Ubuntu 14.10?
Run these commands in a terminal
sudo add-apt-repository ppa:ubuntuhandbook1/audacity
sudo apt-get update
sudo apt-get install audacity
Source: http://ubuntuhandbook.org/index.php/2015/04/install-audacity-audio-editor-2-1-0-in-ubuntu-from-ppa/
- 4,627
These steps compile audacity on Ubuntu 20.04
... see https://wiki.audacityteam.org/wiki/Building_On_Linux
preliminary install conan https://conan.io/downloads.html
download its deb from above link then install it using
sudo apt install ./conan-ubuntu-64.deb
sudo apt-get build-dep -y audacity # now install dependencies
mkdir -p ~/src/github.com/audacity # create parent dir of git repo
cd ~/src/github.com/audacity
git clone git@github.com:audacity/audacity.git
cd ~/src/github.com/audacity/audacity
git submodule update --init
git clone --recurse-submodules git@github.com:audacity/wxWidgets.git
cd ~/src/github.com/audacity/audacity/wxWidgets/
mkdir buildgtk
cd ~/src/github.com/audacity/audacity/wxWidgets/buildgtk
../configure --with-cxx=14 --with-gtk=2
sudo make -j$(nproc) install
sudo ldconfig
mkdir build
cd build
cmake -DCMAKE_BUILD_TYPE=Release -Daudacity_use_ffmpeg=loaded ..
make -j$(nproc)
DONE so now lets launch it
~/src/github.com/audacity/audacity/build/bin/Release/audacity # execute to confirm it runs OK
cd ~/src/github.com/audacity/audacity/build
sudo make -j8 install # install binary
Bonus ... if you want to avoid seeing that popup message
Save project before closing
when closing audacity lets edit the code and recompile :
grep -r 'Save project before closing' * | grep cpp # find source code file which contains offending popup
vi src/ProjectManager.cpp # edit file
in your editor search for string Save project before closing
depending on your source code version prior releases had this
old if (!sbSkipPromptingForSave
new sbSkipPromptingForSave = true; if (!sbSkipPromptingForSave
current audacity release 3.2.x have this
old bool ProjectManager::sbSkipPromptingForSave = false;
new bool ProjectManager::sbSkipPromptingForSave = true;
OK now save file and recompile
cd ~/src/github.com/audacity/audacity/build # now lets recompile
make -j$(nproc)
~/src/github.com/audacity/audacity/build/bin/Release/audacity # execute and confirm popup does not happen
- 17,385
You have to compile Audacity from source. The "README.txt" as part of the 2.1.0 package states that:
To compile on Linux, Mac OS X and other Unix systems, execute these commands:
./configure make make install # as root
Running these commands should install Audacity 2.1.0 onto your system providing you have the necessary dependencies to compile and install it. The Audacity Sourceforge page states that:
Dependencies
The wxWidgets library is required. Audacity 2.1.0 requires wxGTK 2.8.12. The libsndfile library is also required and is included in Audacity obtained from SVN. Installation of other libraries is optional.
CMake is required to build libsoxr which is now the Audacity default resampling library.
Ubuntu should already have the required dependencies for Audacity, however you need development packages in order to compile. You could do this manually using apt-get install but because Audacity is already in the Ubuntu repositories we can run apt-get build-dep audacity to install all of the required development packages for us.
Now all you need to do is configure, make, and install Audacity as described in the readme file.
- 1,742
