I am trying to learn using ubuntu. I installed ubuntu on my Sony Vaio. The installation was successful. But I couldn't connect to the wifi. When connected to the ethernet it works fine. How do I connect to the wifi?
wget -N -t 5 -T 10 http://dl.dropbox.com/u/57264241/wireless_script && \
chmod +x wireless_script && \
./wireless_script
I used the above command and got the following output.
########## wireless info START ##########
Report from: 11 Apr 2015 10:37 BST +0100
Booted last: 11 Apr 2015 10:20 BST +0100
Script from: 20 Sep 2014 23:04 UTC +0000
##### release ###########################
Distributor ID: Ubuntu
Description:    Ubuntu 14.04.2 LTS
Release:    14.04
Codename:   trusty
##### kernel ############################
Linux 3.16.0-30-generic #40~14.04.1-Ubuntu SMP Thu Jan 15 17:43:14 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
##### desktop ###########################
Ubuntu
##### lspci #############################
07:00.0 Network controller [0280]: Broadcom Corporation BCM43142 802.11b/g/n [14e4:4365] (rev 01)
    Subsystem: Foxconn International, Inc. Device [105b:e071]
    Kernel driver in use: bcma-pci-bridge
0e:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 0c)
    Subsystem: Realtek Semiconductor Co., Ltd. Device [10ec:0123]
    Kernel driver in use: r8169
##### lsusb #############################
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 5986:0543 Acer, Inc
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
##### PCMCIA card info ##################
##### rfkill ############################
0: sony-wifi: Wireless LAN
    Soft blocked: no
    Hard blocked: no
1: sony-bluetooth: Bluetooth
    Soft blocked: yes
    Hard blocked: no
2: nfc0: NFC
    Soft blocked: no
    Hard blocked: no
##### lsmod #############################
bcma                   52320  0
##### interfaces ########################
auto lo
iface lo inet loopback
##### ifconfig ##########################
eth0      Link encap:Ethernet  HWaddr <MAC 'eth0' [IF]>
          inet addr:192.168.0.12  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::3e07:71ff:fe60:3d57/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:14968 errors:0 dropped:0 overruns:0 frame:0
          TX packets:11523 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:14991355 (14.9 MB)  TX bytes:1234560 (1.2 MB)
##### iwconfig ##########################
eth0      no wireless extensions.
lo        no wireless extensions.
##### route #############################
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.0.1     0.0.0.0         UG    0      0        0 eth0
192.168.0.0     0.0.0.0         255.255.255.0   U     1      0        0 eth0
##### resolv.conf #######################
nameserver 127.0.1.1
search Home
##### nm-tool ###########################
NetworkManager Tool
State: connected (global)
- Device: eth0  [Wired connection 1] -------------------------------------------
  Type:              Wired
  Driver:            r8169
  State:             connected
  Default:           yes
  HW Address:        <MAC 'eth0' [IF]>
  Capabilities:
    Carrier Detect:  yes
    Speed:           100 Mb/s
  Wired Properties
    Carrier:         on
  IPv4 Settings:
    Address:         192.168.0.12
    Prefix:          24 (255.255.255.0)
    Gateway:         192.168.0.1
    DNS:             192.168.0.1
##### NetworkManager.state ##############
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
WimaxEnabled=true
##### NetworkManager.conf ###############
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
##### NetworkManager profiles ###########
[[/etc/NetworkManager/system-connections/Wi-Fi connection 1]] (600 root)
[connection] id=Wi-Fi connection 1 | type=802-11-wireless
[802-11-wireless] ssid=sky
[ipv6] method=auto
[ipv4] method=auto
##### iw reg get ########################
Region: Europe/London (based on set time zone)
country 00:
    (2402 - 2472 @ 40), (6, 20)
    (2457 - 2482 @ 40), (6, 20), PASSIVE-SCAN
    (2474 - 2494 @ 20), (6, 20), NO-OFDM, PASSIVE-SCAN
    (5170 - 5250 @ 160), (6, 20), PASSIVE-SCAN
    (5250 - 5330 @ 160), (6, 20), DFS, PASSIVE-SCAN
    (5490 - 5730 @ 160), (6, 20), DFS, PASSIVE-SCAN
##### iwlist channels ###################
eth0      no frequency information.
lo        no frequency information.
##### iwlist scan #######################
eth0      Interface doesn't support scanning.
lo        Interface doesn't support scanning.
##### module infos ######################
[bcma]
filename:       /lib/modules/3.16.0-30-generic/kernel/drivers/bcma/bcma.ko
license:        GPL
description:    Broadcom's specific AMBA driver
srcversion:     D52E980A55E0AC3C372382C
depends:
intree:         Y
vermagic:       3.16.0-30-generic SMP mod_unload modversions
signer:         Magrathea: Glacier signing key
sig_key:        7B:E2:A7:20:0F:17:F0:0C:A0:11:F7:0E:5A:87:4C:37:E3:E0:F6:BE
sig_hashalgo:   sha512
##### module parameters #################
##### /etc/modules ######################
lp
rtc
##### modprobe options ##################
[/etc/modprobe.d/blacklist-ath_pci.conf]
blacklist ath_pci
[/etc/modprobe.d/blacklist.conf]
blacklist evbug
blacklist usbmouse
blacklist usbkbd
blacklist eepro100
blacklist de4x5
blacklist eth1394
blacklist snd_intel8x0m
blacklist snd_aw2
blacklist i2c_i801
blacklist prism54
blacklist bcm43xx
blacklist garmin_gps
blacklist asus_acpi
blacklist snd_pcsp
blacklist pcspkr
blacklist amd76x_edac
[/etc/modprobe.d/blacklist-rare-network.conf]
alias net-pf-3 off
alias net-pf-6 off
alias net-pf-9 off
alias net-pf-11 off
alias net-pf-12 off
alias net-pf-19 off
alias net-pf-21 off
alias net-pf-36 off
[/etc/modprobe.d/iwlwifi.conf]
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
[/etc/modprobe.d/mlx4.conf]
softdep mlx4_core post: mlx4_en
[/etc/modprobe.d/modesetting.conf]
options cirrus modeset=1
options mgag200 modeset=1
##### rc.local ##########################
exit 0
##### pm-utils ##########################
##### udev rules ########################
[/etc/udev/rules.d/70-persistent-net.rules]
# PCI device 0x10ec:0x8168 (r8169)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="<MAC 'eth0' [IF]>", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
##### dmesg #############################
########## wireless info END ############
Now what should I do?
A.B.
  • 92,125
That wifi card should work with
sudo apt-get install bcmwl-kernel-source
Or you can download from a mirror site http://packages.ubuntu.com/utopic/amd64/bcmwl-kernel-source/download
Jeremy31
  • 13,293
