Many times my mouse USB suddenly stops working, though the trackpad works just fine. I have to click it to make it work again. I have found the following solution:
sudo bash
for i in /sys/bus/usb/devices/*/power/control; do echo on > $i; done
However, I have to execute this script every time the problem occurs. What is the true reason behind it? How can I fix it permanently?
I am using Ubuntu 14.04 LTS.
mikewhatever
  • 33,013
syntagma
  • 589
  • 15
This happens because the power management switches off usb devices in order to save power after a certain period of inactivity. Although there are solutions to solve this manually I recommend to install software called tlp.
sudo apt-get install tlp
This software offers options to control power management in a safe way without having to set things manually in relevant files, like what you've found to be a solution. It works equally good at both laptops and desktops.
More info about tlp can be found at several sites like for example this one: http://linuxg.net/how-to-install-tlp-0-6-on-ubuntu-14-10-ubuntu-14-04-ubuntu-12-04-and-derivative-systems/
wie5Ooma
  • 1,849
