I have an HP box with a 32bit processor and 80gb hard drive that currently has XP pro as the OS. I downloaded Ubuntu to the hard drive but can't get it to open or boot. I welcome any suggestions.
Asked
Active
Viewed 39 times
- Make a bootable pendrive using any available software (I prefer LiLi for windows).
- Reboot and press F2/F8 to go to Boot Menu.
- Change Boot Priority (Set USB/Flashdrive first using arrow keys).
- Exit and save changes. Reboot.
- Now you will be presented with ubuntu logo and installation proceeds (Try ubuntu/Install Ubuntu).
- If you have created partitions previously, then you can install ubuntu in any one of them.
- Else, you need to create separate partition for ubuntu. Use GParted for doing that.
- How to use GParted ?, Install it while ubuntu is running on your USB from apt-get install command (You should choose 'Try Ubuntu option for this').
If you are looking to test ubuntu without installing, you can use VirtualBox, a free program provided and maintained by Oracle. This way you can create a virtual machine on your windows box and install it there. You would mount the ISO you downloaded as a CD image in the VM's configuration.
If you wanted to install ubuntu you will need to burn the ISO to a thumb drive or dvd. If you are using DVDs I recommend imgburn and for usb drives I like to use Rufus. These are personal preference though.
Andrew Meyer
- 1,557
