I have a problem with my laptop. I installed Ubuntu 14.04 LTS next to Windows 8.1. It is the first time I am using Ubuntu. I don't know exactly what happened but somehow I damaged the Grub bootloader. So I am trying to recover it now and I am following this tutorial:
They both say, I have to mount my root partition. So I am searching for it via
sudo gparted
which gives me the following:
... seems like I am not allowed to post the pictures here ...
so here is what sudo parted -l gives me:
ubuntu@ubuntu:~$ sudo parted -l
Model: ATA SanDisk SSD U100 (scsi)
Disk /dev/sda: 16.0GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Number Start End Size File system Name Flags
1 1049kB 16.0GB 16.0GB HFS
Warning: /dev/sdb contains GPT signatures, indicating that it has a GPT table.
However, it does not have a valid fake msdos partition table, as it should.
Perhaps it was corrupted -- possibly by a program that doesn't understand GPT
partition tables. Or perhaps you deleted the GPT table, and are now using an
msdos partition table. Is this a GPT partition table?
Yes/No? y
Model: ATA ST1000LM024 HN-M (scsi)
Disk /dev/sdb: 1000GB
Sector size (logical/physical): 512B/4096B
1 1049kB 1050MB 1049MB ntfs Basic data partition hidden, diag
2 1050MB 1322MB 273MB fat32 EFI system partition boot, hidden
3 1322MB 2371MB 1049MB fat32 Basic data partition hidden
4 2371MB 2505MB 134MB Microsoft reserved partition msftres
5 2505MB 632GB 629GB ntfs Basic data partition msftdata
6 632GB 742GB 110GB ntfs Basic data partition msftdata
7 742GB 772GB 30.1GB fat32 boot
12 772GB 943GB 171GB ext4
13 943GB 951GB 8535MB linux-swap(v1)
8 951GB 952GB 472MB ntfs hidden, diag
9 952GB 952GB 367MB ntfs hidden, diag
10 952GB 979GB 26.8GB ntfs Basic data partition msftdata
11 979GB 1000GB 21.5GB ntfs Basic data partition hidden, diag
Model: SanDisk Ultra (scsi)
Disk /dev/sdc: 16.0GB
Partition Table: msdos
Number Start End Size Type File system Flags
1 98.3kB 16.0GB 16.0GB primary fat32 boot, lba
According to the tutorial my root partition should be /dev/sdb12 because it is in ext4-format, right?`
But when I try to mount it via
sudo mount /dev/sdb12 /mnt
it says
mount: special device /dev/sdb12 does not exist
A list of recognized drives and partitions by my system (ls /dev/sd*):
/dev/sda /dev/sda1
/dev/sdb /dev/sdb1 /dev/sdb2 /dev/sdb3
/dev/sdc /dev/sdc1
I really hope you can help me.
