I am trying to install php5-curl via terminal in Ubuntu 14.04. I got following error.
sanchit@sanchit-Satellite-A660:~$ sudo apt-get install php5-curl
Reading package lists... Done
Building dependency tree
php5-curl : Depends: php5-common (= 5.5.9+dfsg-1ubuntu4) but 5.5.9+dfsg-1ubuntu4.6 is to be installed
I then did sudo apt-get upgrade. And I am getting the same error.
sanchit@sanchit-Satellite-A660:~$ sudo apt-get upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
At some places it is advised to use Synaptic, but I am keen on solving it using terminal.
