I have been using Gambas3 to write some User interfaces, and Ive really enjoyed the simplicity, and speed at which I can write GUIs with. Now i am ready to publish some software. I tried walking through the publish process last night, but I ended up with a deb file with unsatisfiable dependencies.
There seems to be a wide variety of help documents for writing code, but I haven't found anything that walks one through creating a gambas3 program and "publishing" a deb file.
I seem to have a problem in setting up the dependencies. One simple program depends on the sensors command, and gtk3 or Qt4. (either would work) I will try to post images soon. In the mean time, can someone point me to documentation for publishing gambas3 applications as .deb files?
j0h
  • 15,365
ok, its not a perfect answer, I would perfer to user gambas version 3.7, but instead I uninstalled gambas version 3.7 and installed version 3.1.1. version 3.1.1 is in the repositories. Once I installed version 3.1.1, the package publishing component worked. I was able to produce a deb file, and install my software on some other systems, (after getting some dependencies).
apparently the package publishing feature is broken in version 3.7
j0h
  • 15,365
