I had a Windows 8.1 installed on C partition of my laptop. I had 2 partitions, C and D. Recently I installed Ubuntu Mate 14.04. but I don't know how to find my files on D partition. Should I mount or something?
Any help would be appreciated...
I think the following information would help :
  • sudo fdisk -l:
    Disk /dev/sda: 750.2 GB, 750156374016 bytes 255 heads, 63
    sectors/track, 91201 cylinders, total 1465149168 sectors Units =
    sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512
    bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes
    Disk identifier: 0x00087858
       Device Boot      Start         End      Blocks   Id  System
    /dev/sda1   *        2048      499711      248832   83  Linux
    /dev/sda2          501758  1465147391   732322817    5  Extended
    Partition 2 does not start on physical sector boundary. /dev/sda5
    501760  1465147391   732322816   8e  Linux LVM
    Disk /dev/mapper/ubuntu--vg-root: 745.8 GB, 745789194240 bytes 255
    heads, 63 sectors/track, 90670 cylinders, total 1456619520 sectors
    Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical):
    512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096
    bytes Disk identifier: 0x00000000
    Disk /dev/mapper/ubuntu--vg-root doesn't contain a valid partition
    table
    Disk /dev/mapper/ubuntu--vg-swap_1: 4106 MB, 4106223616 bytes 255
    heads, 63 sectors/track, 499 cylinders, total 8019968 sectors Units =
    Disk /dev/mapper/ubuntu--vg-swap_1 doesn't contain a valid partition
    table
  • df -h:
    Filesystem                   Size  Used Avail Use% Mounted on
    /dev/mapper/ubuntu--vg-root  684G  3.3G  646G   1% /
    none                         4.0K     0  4.0K   0% /sys/fs/cgroup
    udev                         1.9G  4.0K  1.9G   1% /dev
    tmpfs                        388M  1.2M  386M   1% /run
    none                         5.0M     0  5.0M   0% /run/lock
    none                         1.9G  292K  1.9G   1% /run/shm
    none                         100M   48K  100M   1% /run/user
    /dev/sda1                    236M   36M  188M  17% /boot
  • sudo blkid:
    /dev/sda1: UUID="56fa0875-40d6-4bbd-ae2a-f3e85341c44a" TYPE="ext2"
    /dev/sda5: UUID="tQJELc-qT2m-xBFV-RfHJ-f7Vj-LIIn-KpAQ0Q" TYPE="LVM2_member"
    /dev/mapper/ubuntu--vg-root: UUID="8f775671-a8d4-42b1-9ea4-90a7b7899c36" TYPE="ext4"
    /dev/mapper/ubuntu--vg-swap_1: UUID="61daad35-5ff4-4417-b3b6-cbd0943e6a0f" TYPE="swap"
  • fdisk -l | grep NTFS:
    Disk /dev/mapper/ubuntu--vg-root doesn't contain a valid partition         table
    Disk /dev/mapper/ubuntu--vg-swap_1 doesn't contain a valid partition table
A.B.
  • 92,125
Nima
  • 71
Unless you've got another physical disk, it looks like you've accidentally overwritten your Windows installation, including both C: and D: partitions.
If you have good backups, now is the time to use them.
If you do not have good backups, shut down and stop using the disk immediately! Your best hope for recovery is to use a tool like PhotoRec, which can recover files from badly damaged filesystems. (I've heard that some Windows tools can do a better job than PhotoRec on NTFS, but I don't remember the specifics or have pointers to these tools.) You'll need a second disk with sufficient capacity to hold your recovered files, and you'll need to boot to an emergency system to run PhotoRec (or whatever you use instead of it).
Rod Smith
  • 45,120
  • 66
  • 108
-1
You need to mount /dev/sda5 to access D: drive.
Best way to do it temporarily is -
mkdir ~/myDdrive
sudo mount /dev/sda5 ~/myDdrive
To do it permanently, and for all users (and guest), make a /myDdrive (or whatever name you wish) directory in root
sudo mkdir /myDdrive
Then in your /etc/fstab file, add the mount line, that will executed every time, so you always have the drive mounted
/dev/sda5       /myDdrive      ntfs    rw
