I want to monitor the fans in my HTPC due to a recent and inexplicable temperature increase of 5+ degrees C. Package 'lm-sensors' does not detect fan sensors. After some investigation I found there are drivers available for Nuvoton chip in my mobo Z87 PRO:
https://github.com/groeck/nct6775
When making/compiling I get the following error:
~/Z87 Drivers/nct6775-master$ sudo make
**arch/x86/Makefile:136: CONFIG_X86_X32 enabled but no binutils support
Makefile:652: Cannot use CONFIG_CC_STACKPROTECTOR_REGULAR: -fstack-        protector not supported by compiler
make[1]: *** No rule to make target 'Drivers/nct6775-master'.  Stop.
Makefile:30: recipe for target 'modules' failed
make: *** [modules] Error 2**
Any ideas ?
Thanks a lot.
emare
I suggest the following sequence:
sudo apt-get install build-essential linux-headers-generic
cd ~/Z87\ Drivers/nct6775-master
make clean
make
sudo make install
chili555
  • 61,330
