I am attempting the AutopilotBeta deployment of OpenStack on 8 physical servers. I originally had an issue with a missing size attribute (thank you Dell for being ... different). But the latest version of openstack-install has addressed that issue. I was still having some odd authentication issues, so I took my environment back to bare metal and reinstalled from scratch. The MAAS install goes well, no issues. I am able to commission all of the machines. When I attempt to execute the "openstack-install", it makes it through the juju bootstrapping, but fails during the landscape deployment. I will put the pertinent log below. I stripped this environment down to bare metal twice with the same results ... so I am consistent. What am I doing wrong?
[DEBUG • 04-07 13:35:28] • cloudinstall.multi_install • (multi_install.py, do_install, 173)]
Finished MAAS step, now deploying Landscape.
[ERROR • 04-07 13:44:18] • cloudinstall.multi_install • (multi_install.py, run_deployer, 770)]
Problem deploying Landscape: {'output': '2015-04-07 13:35:44
[DEBUG] deployer.cli: Using runtime GoEnvironment on maas\n2015-04-07 13:35:44
[INFO] deployer.cli: Starting deployment of landscape-dense-maas\n2015-04-07 13:35:44
[DEBUG] deployer.import: Getting charms...\n2015-04-07 13:35:44
[DEBUG] deployer.charm: Cache dir /home/peugenis/.cloud-install/juju/.deployer-store-cache/cs_trusty_haproxy-4\n2015-04-07 13:35:44
[DEBUG] deployer.charm: Retrieving store charm cs:trusty/haproxy-4\n2015-04-07 13:35:51
[DEBUG] deployer.charm: Cache dir /home/peugenis/.cloud-install/juju/.deployer-store-cache/cs_trusty_rabbitmq-server-26\n2015-04-07 13:35:51
[DEBUG] deployer.charm: Retrieving store charm cs:trusty/rabbitmq-server-26\n2015-04-07 13:35:57
[DEBUG] deployer.charm: Cache dir /home/peugenis/.cloud-install/juju/.deployer-store-cache/cs_trusty_postgresql-15\n2015-04-07 13:35:57
[DEBUG] deployer.charm: Retrieving store charm cs:trusty/postgresql-15\n2015-04-07 13:36:04
[DEBUG] deployer.charm: Cache dir /home/peugenis/.cloud-install/juju/.deployer-store-cache/cs_trusty_landscape-server\n2015-04-07 13:36:09
[DEBUG] deployer.charm: Retrieving store charm cs:trusty/landscape-server-8\n2015-04-07 13:36:15
[DEBUG] deployer.charm: Cache dir /home/peugenis/.cloud-install/juju/.deployer-store-cache/cs_trusty_landscape-server\n2015-04-07 13:36:15
[DEBUG] deployer.charm: Cache dir /home/peugenis/.cloud-install/juju/.deployer-store-cache/cs_trusty_apache2-10\n2015-04-07 13:36:15
[DEBUG] deployer.charm: Retrieving store charm cs:trusty/apache2-10\n2015-04-07 13:36:22
[DEBUG] deployer.deploy: Resolving configuration\n2015-04-07 13:36:22
[DEBUG] deployer.env: Connecting to environment...\n2015-04-07 13:36:22
[DEBUG] deployer.env: Connected to environment\n2015-04-07 13:36:22
[INFO] deployer.import: Deploying services...\n2015-04-07 13:36:22
[DEBUG] deployer.import: <deployer.env.go.GoEnvironment object at 0x7f32ce001c10>\n2015-04-07 13:36:23
[INFO] deployer.import:  Deploying service apache2 using cs:trusty/apache2-10\n2015-04-07 13:36:23
[DEBUG] deployer.import:  Refetching status for placement deploys\n2015-04-07 13:36:44
[DEBUG] deployer.import:  Setting annotations\n2015-04-07 13:36:44
[INFO] deployer.import:  Deploying service haproxy using cs:trusty/haproxy-4\n2015-04-07 13:37:00
[DEBUG] deployer.import:  Setting annotations\n2015-04-07 13:37:00
[INFO] deployer.import:  Deploying service landscape using cs:trusty/landscape-server\n2015-04-07 13:37:22
[DEBUG] deployer.import:  Setting annotations\n2015-04-07 13:37:23
[INFO] deployer.import:  Deploying service landscape-msg using cs:trusty/landscape-server\n2015-04-07 13:37:41
[DEBUG] deployer.import:  Setting annotations\n2015-04-07 13:37:42
[INFO] deployer.import:  Deploying service postgresql using cs:trusty/postgresql-15\n2015-04-07 13:37:58
[DEBUG] deployer.import:  Setting annotations\n2015-04-07 13:37:58
[INFO] deployer.import:  Deploying service rabbitmq-server using cs:trusty/rabbitmq-server-26\n2015-04-07 13:38:14
[DEBUG] deployer.import:  Setting annotations\n2015-04-07 13:38:20
[DEBUG] deployer.import: Adding units...\n2015-04-07 13:38:20
[DEBUG] deployer.import:  Service \'apache2\' does not need any more units added.\n2015-04-07 13:38:20
[DEBUG] deployer.import:  Service \'haproxy\' does not need any more units added.\n2015-04-07 13:38:20
[DEBUG] deployer.import:  Service \'landscape\' does not need any more units added.\n2015-04-07 13:38:20
[DEBUG] deployer.import:  Service \'landscape-msg\' does not need any more units added.\n2015-04-07 13:38:20
[DEBUG] deployer.import:  Service \'postgresql\' does not need any more units added.\n2015-04-07 13:38:20
[DEBUG] deployer.import:  Service \'rabbitmq-server\' does not need any more units added.\n2015-04-07 13:38:20
[DEBUG] deployer.import: Waiting for units before adding relations\n2015-04-07 13:40:02
[DEBUG] deployer.env:  Delta machine: 0/lxc/0 change:pending\n2015-04-07 13:40:12
[DEBUG] deployer.env:  Delta machine: 0/lxc/1 change:pending\n2015-04-07 13:40:22
[DEBUG] deployer.env:  Delta machine: 0/lxc/0 change:pending\n2015-04-07 13:40:22
[DEBUG] deployer.env:  Delta machine: 0/lxc/0 change:started\n2015-04-07 13:40:22
[DEBUG] deployer.env:  Delta unit: apache2/0 change:installing\n2015-04-07 13:40:22
[DEBUG] deployer.env:  Delta machine: 0/lxc/2 change:pending\n2015-04-07 13:40:32
[DEBUG] deployer.env:  Delta machine: 0/lxc/3 change:pending\n2015-04-07 13:40:47
[DEBUG] deployer.env:  Delta machine: 0/lxc/4 change:pending\n2015-04-07 13:40:57
[DEBUG] deployer.env:  Delta machine: 0/lxc/1 change:pending\n2015-04-07 13:40:57
[DEBUG] deployer.env:  Delta machine: 0/lxc/1 change:started\n2015-04-07 13:40:57
[DEBUG] deployer.env:  Delta machine: 0/lxc/2 change:pending\n2015-04-07 13:40:57
[DEBUG] deployer.env:  Delta unit: haproxy/0 change:installing\n2015-04-07 13:40:57
[DEBUG] deployer.env:  Delta machine: 0/lxc/2 change:started\n2015-04-07 13:40:57
[DEBUG] deployer.env:  Delta unit: landscape/0 change:installing\n2015-04-07 13:40:57
[DEBUG] deployer.env:  Delta machine: 0/lxc/3 change:started\n2015-04-07 13:40:57
[DEBUG] deployer.env:  Delta unit: landscape-msg/0 change:allocating\n2015-04-07 13:41:02
[DEBUG] deployer.env:  Delta machine: 0/lxc/5 change:pending\n2015-04-07 13:41:02
[DEBUG] deployer.env:  Delta unit: landscape-msg/0 change:installing\n2015-04-07 13:41:02
[DEBUG] deployer.env:  Delta unit: landscape-msg/0 change:installing\n2015-04-07 13:41:12
[DEBUG] deployer.env:  Delta machine: 0/lxc/4 change:pending\n2015-04-07 13:41:12
[DEBUG] deployer.env:  Delta machine: 0/lxc/4 change:started\n2015-04-07 13:41:13
[DEBUG] deployer.env:  Delta unit: postgresql/0 change:installing\n2015-04-07 13:41:13
[DEBUG] deployer.env:  Delta unit: apache2/0 change:installing\n2015-04-07 13:41:18
[DEBUG] deployer.env:  Delta unit: haproxy/0 change:installing\n2015-04-07 13:41:23
[DEBUG] deployer.env:  Delta machine: 0/lxc/5 change:pending\n2015-04-07 13:41:23
[DEBUG] deployer.env:  Delta machine: 0/lxc/5 change:started\n2015-04-07 13:41:23
[DEBUG] deployer.env:  Delta unit: rabbitmq-server/0 change:allocating\n2015-04-07 13:41:28
[DEBUG] deployer.env:  Delta unit: apache2/0 change:started\n2015-04-07 13:41:28
[DEBUG] deployer.env:  Delta unit: rabbitmq-server/0 change:installing\n2015-04-07 13:41:28
[DEBUG] deployer.env:  Delta unit: rabbitmq-server/0 change:installing\n2015-04-07 13:41:38
[DEBUG] deployer.env:  Delta unit: haproxy/0 change:started\n2015-04-07 13:41:58
[DEBUG] deployer.env:  Delta unit: postgresql/0 change:installing\n2015-04-07 13:41:58
[DEBUG] deployer.env:  Delta unit: postgresql/0 change:installing\n2015-04-07 13:42:08
[DEBUG] deployer.env:  Delta unit: postgresql/0 change:started\n2015-04-07 13:42:43
[DEBUG] deployer.env:  Delta unit: rabbitmq-server/0 change:installing\n2015-04-07 13:44:18
[DEBUG] deployer.env:  Delta unit: landscape-msg/0 change:error\n2015-04-07 13:44:18
[ERROR] deployer.env: The following units had errors:\n   unit: landscape-msg/0: machine: 0/lxc/3 agent-state: error details: hook failed: "install"\n2015-04-07 13:44:18
[INFO] deployer.cli: Deployment stopped. run time: 513.42\n', 'status': 1}
[DEBUG • 04-07 13:44:18] • cloudinstall.utils • (utils.py, global_exchandler, 63)]
Traceback (most recent call last):
 File "/usr/share/openstack/cloudinstall/utils.py", line 78, in run
super().run()
 File "/usr/lib/python3.4/threading.py", line 868, in run
self._target(*self._args, **self._kwargs)
 File "/usr/share/openstack/cloudinstall/machinewait.py", line 127, in do_continue
 self.installer.do_install()
 File "/usr/share/openstack/cloudinstall/multi_install.py", line 177, in do_install
self.loop).run()
File "/usr/share/openstack/cloudinstall/multi_install.py", line 708, in run
self.deploy_landscape()
File "/usr/share/openstack/cloudinstall/multi_install.py", line 731, in deploy_landscape
self.run_deployer()
  File "/usr/share/openstack/cloudinstall/multi_install.py", line 771, in   run_deployer
raise Exception("Error deploying Landscape.")
Exception: Error deploying Landscape.
Additional information. I am seeing the following errors in the landscape log on the machine being deployed to:
2015-04-07 20:44:29 INFO unit.landscape/0.install logger.go:40
2015-04-07 20:44:29 INFO unit.landscape/0.install logger.go:40 E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/universe/z/zope.browserresource/python-zope.browserresource_3.12.0-0ubuntu1_all.deb  503  Service Unavailable
But I am able to wget that file from that machine.
Two lines from the /var/log/maas/proxy/store.log that relate to the above:
1428439419.359 RELEASE -1 FFFFFFFF 3C1B6A761DD7EF328EC4C7C7822C849A  503 1428439419         0        -1 text/html 3571/3571 GET http://archive.ubuntu.com/ubuntu/pool/universe/z/zope.browserresource/python-zope.browserresource_3.12.0-0ubuntu1_all.deb
1428439419.367 RELEASE -1 FFFFFFFF 46EC83BBA3477FFD0A0EE9199555EA91  503 1428439419         0        -1 text/html 3571/3571 GET http://archive.ubuntu.com/ubuntu/pool/universe/z/zope.browserresource/python-zope.browserresource_3.12.0-0ubuntu1_all.deb
0xF2
  • 3,155
Pat E
  • 45
Lots of units deployed just fine according to your log, just landscape-msg/0 failed:
It would be very helpful if you could get the unit-landscape-msg-0.log file from /var/log/juju in the bootstrap node.
You can also check the proxy logs on the maas server at /var/log/maas/proxy/ and see if there was some random failure while packages were being fetched via apt-get.
