I am running 14.04 LTS.
Kernel updates will not install or uninstall.
The boot space (approx 240Mb) is now full and using sudo apt-get autoremove, autoclean, clean or remove will not work.
This all started with kernel update 3.13.0-47.
No space is freed and the following comes up.....
Reading package lists... Done
Building dependency tree
0 to upgrade, 0 to newly install, 0 to remove and 60 not to upgrade.
7 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up linux-image-3.13.0-47-generic (3.13.0-47.78) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
The link /initrd.img is a dangling linkto /boot/initrd.img-3.13.0-48-generic
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.13.0-47-generic /boot/vmlinuz-3.13.0-47-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.13.0-47-generic /boot/vmlinuz-3.13.0-47-generic
update-initramfs: Generating /boot/initrd.img-3.13.0-47-generic
gzip: stdout: No space left on device
E: mkinitramfs failure cpio 141 gzip 1
update-initramfs: failed for /boot/initrd.img-3.13.0-47-generic with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-3.13.0-47-generic.postinst line 1025.
dpkg: error processing package linux-image-3.13.0-47-generic (--configure):
subprocess installed post-installation script returned error exit status 2
Setting up linux-image-3.13.0-48-generic (3.13.0-48.80) ...
Running depmod.
The link /initrd.img is a dangling linkto /boot/initrd.img-3.13.0-47-generic
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.13.0-48-generic /boot/vmlinuz-3.13.0-48-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.13.0-48-generic /boot/vmlinuz-3.13.0-48-generic
update-initramfs: Generating /boot/initrd.img-3.13.0-48-generic
update-initramfs: failed for /boot/initrd.img-3.13.0-48-generic with 1.
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-3.13.0-48-generic.postinst line 1025.
dpkg: error processing package linux-image-3.13.0-48-generic (--configure):
dpkg: dependency problems prevent configuration of linux-image-extra-3.13.0-48-generic:
linux-image-extra-3.13.0-48-generic depends on linux-image-3.13.0-48-generic; however:
Package linux-image-3.13.0-48-generic is not configured yet.
dpkg: error processing package linux-image-extra-3.13.0-48-generic (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-image-generic:
linux-image-generic depends on linux-image-3.13.0-48-generic; however:
linux-image-generic depends on linux-image-extra-3.13.0-48-generic; however:
Package linux-image-extra-3.13.0-48-generic is not configured yet.
dpkg: error processing package linux-image-generic (--configure):
dpkg: dependency problems prevent configuration of linux-generic:
linux-generic depends on linux-image-generic (= 3.13.0.48.55); however:
Package linux-image-generic is not cNo apport report written because the error message indicates it's a follow-up error from a previous failure.
No apport report written because MaxReports has already been reached
onfigured yet.
dpkg: error processing package linux-generic (--configure):
Setting up linux-image-extra-3.13.0-46-generic (3.13.0-46.79) ...
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.13.0-46-generic /boot/vmlinuz-3.13.0-46-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.13.0-46-generic /boot/vmlinuz-3.13.0-46-generic
update-initramfs: Generating /boot/initrd.img-3.13.0-46-generic
update-initramfs: failed for /boot/initrd.img-3.13.0-46-generic with 1.
dpkg: error processing package linux-image-extra-3.13.0-46-generic (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of linux-image-extra-3.13.0-47-generic:
linux-image-extra-3.13.0-47-generic depends on linux-image-3.13.0-47-generic; however:
Package linux-image-3.13.0-47-generic is not configured yet.
> dpkg: error processing package linux-image-extra-3.13.0-47-generic (--configure):
How can this be fixed without doing a reinstall? I tried to resize the boot area and GParted will not let me.
