I am new to Ubuntu, I installed Ubuntu 14.04 on my Sony Vaio VPCEH38FN Laptop. I am not able to change the brightness in my system.
In my system Fn+F5 and Fn+F6 buttons are used to change the brightness, but it is not working. How can I adjust the brightness?
Mudit Kapil
  • 2,081
there are two ways to do this:
First Method: Try this if you want to change brightness using hotkeys (Fn+F5 and Fn+F6)
Open the terminal and type the following command:
gksudo gedit /etc/default/grub
Enter your password and it will open the file in gedit. You need to find two variables and add their value as below. If the variables are already there just mark them as comment by writing # at the start of the line.
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
GRUB_CMDLINE_LINUX="acpi_osi=Linux"
Save the file and close. Now you need to update that file using the following command:
sudo update-grub
Restart your laptop and hotkeys should be work fine.
For more info.
Second Method: Now if you want to adjust screen brightness very precisely, then you should go for this solution. For this you need to open a terminal and change brightness from there.
sudo setpci -s 00:02.0 F4.B=xx
Note: in above command xx = all hexadecimal value between 00 to ff [00=highest brightness ff=lowest brightness(total dark)])
For more info.
Fabby
  • 35,017
Alternate way:
Go to System Settings by typing system settings in dash (by default it will be available on the left side pan). You will find the option Brightness and Lock under personal:
Brightness and Lock
Now open Brightness and Lock and change the brightness accordingly:
heemayl
  • 93,925
