I installed an partition image (Ubuntu 14.04) from another computer to my computer (previously Ubuntu 12.04) using clonezilla. The system partition on the other computer was sda1 and on my computer its sda4 (I have a multiboot system with windows, MBR, UEFI, SWAP on the other sda's). After installing the image my computer cannot boot anymore since grub cannot find the new Ubuntu 14.04 on sda4. Unfortunatly I cannot run boot-repair neither from a stick nor from within an Ubuntu live session. Does anyone know how to repair my grub?
Here is the first part of the output of the boot repair error log file:
Boot Info Script e7fc706 + Boot-Repair extra info      [Boot-Info 9Feb2015]
============================= Boot Info Summary: ===============================
 => Grub2 (v1.99-2.00) is installed in the MBR of /dev/sda and looks at sector
    386664576 of the same hard drive for core.img, but core.img can not be
    found at this location.
 => No boot loader is installed in the MBR of /dev/sdb.
 => Syslinux MBR (4.04 and higher) is installed in the MBR of /dev/sdc.
 => Syslinux MBR (4.04 and higher) is installed in the MBR of /dev/sdh.
sda1: __________________________________________________________________________
    File system:       vfat
    Boot sector type:  Windows 7/2008: FAT32
    Boot sector info:  No errors found in the Boot Parameter Block.
    Operating System:
    Boot files:        /EFI/Boot/bkpbootx64.efi /EFI/Boot/bootx64.efi
                       /EFI/ubuntu/grubx64.efi /EFI/ubuntu/shimx64.efi
                       /EFI/Microsoft/Boot/bkpbootmgfw.efi
                       /EFI/Microsoft/Boot/bootmgfw.efi
                       /EFI/Microsoft/Boot/bootmgr.efi
                       /EFI/Microsoft/Boot/bootx64.efi
                       /EFI/Microsoft/Boot/memtest.efi
sda2: __________________________________________________________________________
    File system:
    Boot sector type:  -
    Boot sector info:
    Mounting failed:   mount: unknown filesystem type ''
sda3: __________________________________________________________________________
    File system:       ntfs
    Boot sector type:  Windows 7/2008: NTFS
    Operating System:  Windows 7
    Boot files:        /Windows/System32/winload.exe
sda4: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:  Ubuntu 14.04.1 LTS
    Boot files:        /boot/grub/grub.cfg /etc/fstab
                       /boot/grub/i386-pc/core.img
sda5: __________________________________________________________________________
    File system:       swap
    Boot sector type:  -
    Boot sector info:
mcExchange
  • 3,398
It looks like the source computer, at least, used EFI. If the new computer also uses EFI, you should be able to use my rEFInd boot manager as an emergency boot system:
  1. Download the CD-R or USB flash drive version from the downloads page.
  2. Prepare a boot medium from said image.
  3. Boot rEFInd. This may require using your computer's built-in boot manager, typically accessed via a function key.
  4. rEFInd should show you options for all your Linux kernels. Select one and hit the Enter key.
With any luck the computer will start up. You can then either install rEFInd via the Debian package or PPA or run Boot Repair.
If you have problems, you may need to boot an emergency system and edit your /etc/fstab file for your new system, since it's possible your filesystem UUIDs have changed. The easiest thing to do in this case is to change the first entry for your / line to read /dev/sda4 rather than UUID={whatever}. With a little more effort, you can use blkid to learn the new UUID value(s) and make the appropriate substitutions.
Rod Smith
  • 45,120
  • 66
  • 108
