I am attempting to determine the exact frame rate of an H.264-encoded video. Using avprobe, I can obtain the following information:
avprobe version 11-6:11-1, Copyright (c) 2007-2014 the Libav developers
  built on Sep 26 2014 14:36:31 with gcc 4.9.1 (Ubuntu 4.9.1-15ubuntu1)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'VID_20150406_175035.mp4':
  Metadata:
  Duration: 00:00:17.00, start: 0.000000, bitrate: 41925 kb/s
    Stream #0.0(eng): Video: h264 (Baseline), yuv420p, 3840x2160, 41941 kb/s, PAR 65536:65536 DAR 16:9, 28.42 fps, 90k tbn (default)
The frame rate is given as 28.42 fps. However, it doesn't provide the exact fractional value. For example, 29.97 is a decimal approximation of the fractional value 30000/1001.
How do I obtain this information?
Nathan Osman
  • 32,495
I reckon you're not interested anymore, but for anyone else finding this question through Google, the answer is here. I'll shamelessly copy and paste the command. Replace "infile" with your filename.
ffprobe -v 0 -of csv=p=0 -select_streams v:0 -show_entries stream=r_frame_rate infile
