I'm learning how to use Ubuntu Server, and after making my first install i realized that my partitions weren't correctly set up. It's way to complicated to fix now, and I regret not using my entire disk, so I want to reinstall everything from scratch. I don't care about saving any data or settings or anything.
This might sound silly, but the problem I am having now is simply accessing the live disk again. Now that I have successfully installed Ubuntu Server, every time I try to boot the Live USB, it redirects me to the installed version on my disk.
How do i bypass this and simply reinstall Ubuntu Server again?
nic
  • 101
During the installation, I was asked if I wanted GRUB to be installed on the harddrive to simplify dual boot. Somehow it was installed on the USB instead of the harddrive. Because of this, every time I tried booting from the USB, it bypassed the live-usb and kept on booting the server instead.
To solve it I just created a new live-usb.
nic
  • 101
You may have to enter your BIOS and change the boot device order to ensure that the USB is booted first. Unfortunately the procedure for this varies widely between manufacturers but generally a message will appear briefly after a restart telling you which key to press to enter the BIOS or Setup or Configuration screens. Then find the boot order settings and ensure that USB is first.
