What comes after the second CHROMIUM_FLAGS= in gedit?
I did the wrong thing when trying to install pepper flash. i went by confusing instructions and now i want to just return this file to normal, i get an error in terminal when i edit it if i dont get it right. here's my file:
# Default settings for chromium-browser. This file is sourced by /bin/sh from
# /usr/bin/chromium-browser
# Options to pass to chromium-browser
CHROMIUM_FLAGS=""
# part for pepperflashplugin-nonfree : begin
flashso="/usr/lib/pepperflashplugin-non...
if [ -f $flashso ]
then
flashversion=`strings $flashso|grep ^LNX|sed -e "s/^LNX //"|sed -e "s/,/./g"`
CHROMIUM_FLAGS=". /usr/lib/pepflashplugin-installer/pepfla...
fi
# part for pepperflashplugin-nonfree : end
The file is called *default ( in /etc/chromium-browser) and the line after CHROMIUM_FLAGS= is where i messed up but i saved it without knowing, what goes after?
heemayl
  • 93,925
You can go back to the default state by removing changes made to the file /etc/chromium-browser/default.
If you want to keep the current file /etc/chromium-browser/default, then rename the file as something else than default e.g. default.bak. Now create a file named default having nothing or only the line CHROMIUM_FLAGS="".
To summarize:
sudo mv /etc/chromium-browser/default /etc/chromium-browser/default.bak
echo 'CHROMIUM_FLAGS=""' | sudo tee -a /etc/chromium-browser/default
heemayl
  • 93,925
