How do I synchronize contacts and calendars from OwnCloud with the Ubuntu phone?
Asked
Active
Viewed 6,098 times
10
The Ubuntu phone uses the evolution data server and the data can be synchronized using syncevolution.
- Open an ssh-connection to your Ubuntu Phone (I'm using the Ubuntu-SDK for this purpose)
Then execute
syncevolution --configure --keyring=no --template webdav username=- password='OCPASSWORD' syncurl="YOURSERVER.COM/owncloud" target-config@owncloud- everything that's written in capitals needs to be replaced with your custom owncloud parameters.
- if you are using a self-signed certificate you would download it from the server, save it locally and tell syncevolution where to find it
SSLServerCertificates="/home/phablet/YOURCERTIFICATE.crt". You can place this command just after the URL parameter. - if the above doesn't work, you could use this unsecure alternative
SSLVerifyServer="0"
Now tell syncevolution the information about the phone
syncevolution --configure --template SyncEvolution_Client sync=none syncURL=local://@owncloud username= password= owncloudand the specific parameters for the calendar
syncevolution --configure --template webdav database=https://YOURSERVER.COM/owncloud/remote.php/caldav/calendars/OCUSER/personal backend=caldav target-config@owncloud calendarThe database path, can be found in the owncloud web frontend by clicking the chain symbol.
now
syncevolution --configure sync=two-way backend=calendar database=personal owncloud calendarand finally start the synchronization
syncevolution --sync slow owncloud calendar
For synchronizing the contacts you would just need to add this steps:
syncevolution --configure --template webdav database=https://YOURSERVER.COM/owncloud/remote.php/carddav/addressbooks/OCUSER/contacts backend=carddav target-config@owncloud contactsyou can again get the right path from the web frontend
syncevolution --configure sync=two-way backend=contacts database=personal owncloud contactsdatabase is the name of the address book on your device
now run
syncevolution --sync slow owncloud contacts
