I want to execute
expect -c "
    spawn ssh user@10.0.0.0
    expect \"assword:\"
    send \"pass\r\"
    interact "
in a new terminal by doing double click in an .sh script.
I tried
#!/bin/bash
commands () {
    expect -c "
    spawn ssh root@10.0.0.0
    expect \"assword:\"
    send \"pass\r\"
    interact "
    $SHELL # keep the terminal open after the previous commands are executed
export -f commands
gnome-terminal -e "bash -c 'commands'"
with no luck. Any ideas?
  1. You can use gnome-terminal with the --disable-factory option that does:
    "Do not register with the activation name server, and do not reuse an already running GNOME terminal process"
    It will let the 'commands' environment variable through.
    gnome-terminal typically runs in a server mode. First launch starts a process, next launches send messages to main process to open a new window. So, env vars are set only on the first launch.
  2. You can use a separate script file and pass its file name to bash. Or make it clever: detect inside this script its actual file name and pass it to bash, so it'll call this same script inside the gnome-terminal (but pass a parameter to take a different code path).
  3. You can stuff everything into a variable, but make sure that it expands before the call to the gnome-terminal.
Velkan
  • 3,681
