-1
After shrinking and increasing the size of a disk in Windows 8 .... this is the error that i get when i start up my PC , it says .... Entering GRUB Rescue Mode.
I solved it. The problem was that the filesystem containing Ubuntu had been moved in the process and GRUB could not locate it. All I did was to locate the correct filesystem and set it as root and voila!
Steps:
  1. Search the filesystems by using ls command.
    ls
  2. Look for a filesystem that is recognized by GRUB.
    ls (hd0,msdos6) {in my case , its msdos6}
  3. Set root to that filesystem.
    set root=(hd0,msdos6)
    set prefix=(hd0,msdos6)/boot/grub
    insmod normal
    normal
This did work, but every time I restart I need to type the same thing over and over. Hope it helps !!
karel
  • 122,292
  • 133
  • 301
  • 332
