I use Nvidia driver 346 and I have followed the instructions of this link How to fix plymouth (splash screen) in all Ubuntu releases! But I've only managed to show the boot splash screen but not the shutdown's as you can see in this video.
I guess it's probably due to that there is no D-sub socket on the video card and I have to use the HDVI to D-sub adaptor which made Ubuntu unable to detect it. Please help me with the issue. Thanks in advance. This is what I did:
sudo apt-get install v86d
sudo gedit /etc/default/grub
GRUB_GFXMODE=1024x768x32
GRUB_GFXPAYLOAD_LINUX=keep
echo FRAMEBUFFER=y | sudo tee /etc/initramfs-tools/conf.d/splash
sudo update-initramfs -u
sudo update-grub2
There is boot-up splash screen, but no shut-down splash. How can I make shut-down splash work?
Config:
- Ubuntu 14.04 64 bit
- Motherboard Gigabyte G1-sniper H6
- CPU intel® Core™ i7-4790 CPU @ 3.60GHz × 8
- Video Card Nvidia GeForce GTX 750 Ti/PCIe/SSE2 without D-sub
- DVI to D-sub adaptor
- Display LG E2242C LCD with only a D-sub socket
grub.conf:
GRUB_DEFAULT=0
#GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
#Fix nvidia splash screen
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
