I want to buy a mouse for my PC, but as I was searching I saw in the product details that it had to have Windows as the OS. I have a Ubuntu/Windows duel boot and I was wondering if mice for Windows can also be used on Ubuntu.
Basic USB/USB wireless mice normally work (still have to find one that doesn't).
If the mouse is a gaming/special mouse, it depends. Most of the time it will just work as a normal mouse or will require quite a lot of configuration, unless the manufacturer explicitly support Linux. Said in other way, the additional buttons will probably be recognized by the system, but they are not normally assigned to anything, and if the manufacturer does not provide info, configuring them will be a bit of a pain.
You can see something in the Ubuntu Community help and in the (as ever) nicely and complete Arch wiki help page (most of it will work in Ubuntu too, but you have to adapt conf files locations and so on).
If you think of a specific mouse, you can ask (please --- another) specific question to see if anyone with the same model has solved the thing for you.
- 32,167
The short answer is yes.
If is a USB (wired or wireless) mouse, all usb mouses (all which I know) are universal and they uses USB HID (human interface device).
If is a Bluetooth mouse there aren't so many troubles.
Any mouse (wired or wireless) that has more than 3 buttons can give some troubles, however, I have one with back and forth buttons that worked plugging it.
- 9,110
- 7
- 38
- 55
If it is just a standard, three button, usb mouse, it should. Linux comes with drivers that work with most hardware.
A lot of hardware will say that they work with just Windows and/or Mac. I have Linux Mint (which is basically the same thing as Ubuntu) connected to the Internet with a usb adapter that says it will only work with Windows, and it works perfectly on linux.
From my experience both of your choices should work, since they all have build-in memory. I had the same problem recently, did some google research and decided to buy Cooler Master Recon. People already confirmed it's compability with Linux. The keys and the lights worked out of the box, but it was also declared to work only under Windows.
Same thing with the previous A4 Tech. It show no problems as well, I believe because of build-in memory.
Though, you will have to download manufacturer software, install it in Windows to configure your mouse the way you want.
- 1,290
